1980 Pontiac LeMans Station Wagon - G-T-faux (stuck with it, and can't shake it... like a bad case of herpes)
motorheadmike
8,976
27,522
Saskatchewan, Truckistan
online170 said:
motorheadmike said:
In other news... these are done - just waiting for the paint to dry.
Thats really cool! My car has no bracing at all, none! And its making a good bit of torque. I was thinking about boxing a separate frame or something but the entire idea is exhausting to even think about. This is a much nicer deal.
So did you have to weld anything to the frame? Or do the smaller pieces act as a "washer" on the back side?
That is pretty much it. The nuts/plates are laid inside the frame rails and when the bolts are tightened (currently 150ft/lbs lubricated) the bottom of the frame is drawn down, and the SFC up, preloading the flexible unboxed section of the frame.
When I get the suspension back under the car I will be able to confirm if the SFCs have done their job when jacking the front or rear corner, and have the opposite end of the frame/tire rise up - the same way it would if the frame were fully boxed.
online170
726
319
I dont see why not. Plus that Gforce member will do quite a bit in my mind to tie the two sides together. Maybe you should patent this idea. Many more chassis that it applies to!
motorheadmike
8,976
27,522
Nah. Hotrodding should be open-source - I hope someone improves on the design.
  • Winner
axisg
2,685
2,354
YYZ
that's pretty cool ! Hows the eye ?? Cant be fun having somebody digging stuff out. I have come close myself and now ( reluctantly ) wear goggles
motorheadmike
8,976
27,522
Eye is healed, wore contacts for the first time in weeks today - so that is a plus. It is aweful when even your assumed protection is circumvented by 10,000rpm of spinning fury.
axisg
2,685
2,354
YYZ
don't I know it ( and have the 6" scar to prove it ) !! Be careful
motorheadmike
8,976
27,522
ssbrewskyaz said:
Hey Mike,
I don't recall; Is this a driver car or race car? Maybe the answer is Yes. Just curious. ...
Scott. ...
Family car. ;)
I am building this as a 3 season driver for tooling around with the family, going to cruise nights, going camping, hitting the drags (still not sure if it will get setup for autocross); and yes we are even considering using it for Drag Week next year... and I can only guess how it will snowball from there.
I may be turning this into a turbo'd build... for reasons I can't yet say.
