I put some miles on it this week- drove it about an hour on the highway, it drives perfectly smooth at 80 LOL the tires need to be balanced for sure...
I found out though that my torque converter was locked up- If I started the car and put it in drive it would stall, and I could not time it right because the motor was being lugged down. So I went to my Hot Rod buddies house, and we jacked it up, started it, put it in drive, and put my foot on the brake and it killed the motor. So I know the tq converted is locked up. My buddy gave me a stock stall converter that has 500 miles on it, and on Sunday I pulled the trans down, swapped the converter and put the trans back in.
Last night I got most of the loose ends tied back up, got new rubber cooler lines in, all the cables hooked back up, changed the trans filter (and I was happy to find a shift kit already installed in the transmission!!), and swapped out the Vacuum module with another that I had because it was the wrong one, and I think it was sucking fluid through the modulator.
All I have left to do is bolt the torque converter up, and fill it with fluid then rip it! I was getting depressed cause I just want to drive the thing lol
Oh one other thing... The 'cool' black headlights I bought, SUCK!! they don't reflect enough light, and the crappy chinese light bulbs were causing power to back feed through my high beams when low beams were on and vice versa. I put factory bulbs back in, no issues. The rubber seals they gave with the headlights did not work with the headlight buckets even after I trimmed them, so when I drove the car in the dewey morning, the headlights fogged up really badly. I guess $25 for 2 headlighs was a bad deal after all...
