BUILD THREAD 1982 Malibu Wa-GOON 6.2/4L80e/8.5
Misfitmike63
Apr 11, 2023
74
332
53
Friend adapted the 3” holley kit to fit around the coilovers, as well as the TNT loop and G-force crossmember. Tuning will start tomorrow. Video to follow!!
Misfitmike63
Apr 11, 2023
74
332
53
Moved the mounting of my XMax screen. Friend 3D printed a bracket for it. Even with the shifter in drive, it goes just below it.
Also, drove the car home, and I had a smile the whole way! Can’t wait to put some miles on it after I clean it up a little. I ordered a larger transmission pan, and a new dipstick as well. Going to have to modify the engine oil dipstick, as it holds the spark plug wire against the header.
doood
Amateur Mechanic
Sep 24, 2020
590
806
I used the same exhaust kit (with manifolds though) and have had much trouble with clamping it since some of the segments aren't round. I've used expanders to try to round it out and torn it at the driver x-pipe inlet. I see you've welded it in numerous places, so you'll probably be better off. I swapped out the mufflers for quieter and cheaper thrush turbo mufflers. I'm so dissatisfied with it, I may eventually go with a 4" single pipe, or weld it in, like you did. Also the body mount rubbers dry rotted within a year.
Could you comment on the rear coil relocation you've done. What did that accomplish for you? Perhaps I'll look into doing that when I put my 8.5" in the Monte Carlo.
Sweet_Johnny
Has A Face For Radio
708
1,280
Wichita, Kansas
Nice placement of the XMax screen, it almost kind of tucks in there which is much better than hanging out by the radio or blocking the gauges.
Misfitmike63
Apr 11, 2023
74
332
53
when I opened the kit, only 1 pipe was out of round, but I fixed it with an expander. My friend just tack welded the clamps in place on 1 side to assist with assembly/disassembly.
as for the coil relocation, it’s a coilover setup from UMI. It gives you more adjustability with the suspension. It actually got in the way of the mounts for the Holley exhaust, so that was something my friend at the exhaust shop had to fix.
Misfitmike63
Apr 11, 2023
74
332
53
Been wicked busy, but got the front wheels on and got it inspected. Hoping to get some miles on it before the snow comes
Reactions: 8 users
Misfitmike63
Apr 11, 2023
74
332
53
Put my dads malibu and my flatbed away for the winter. While cleaning, found LED headlights I bought for my 2 door. Think I need to buy a set for the wagon now.
Misfitmike63
Apr 11, 2023
74
332
53
With the winter coming in New England, I’ve been sidetracked with construction and also house stuff. Recently started finalizing permanent heat for the garage, going with a ceiling mounted 60,000 btu heater. Hopefully it’ll arrive soon! Just got some new 6’ ceiling fans mounted, and can definitely notice much more air flow!
Reactions: 7 users
