I think at cruise, with such little air going thru the intake pipe it slowly just heats up to underhood Temps. The radiator fan is literally blowing hot radiator air right on it. With such little air movement the temp sensor is probably heat soaked and not a good indicator of actual air Temps, because everytime I stab it, even if it's not a long pull, I see iat drop. Sensor is just probably cooling down with all the 80f-100f going by it. If the iat were really that high I would think it would read that basically right away when I start driving the car.I’d take that an indicator that your Procharger makes heat at low or no boost, but the intercooler overcomes that as the pressure increases.
I’m guessing it’s the non China intercooler advantage lol. Dang, I need one of those.
How hard have you ran it? Any track plans soon?
I am currently spinning the blower to. Max rpms. Not sure I'll be going to the track till it cools down a bit, but I might go to the dyno next week.
