This is like the Yang to your Yin, isn't it Rktpwrd ?
Most definitely. The kind of shizz that would keep me up at night and give me nightmares!
If there was a car that was the physical manifestation of my polar opposite, this would be it.
I’m sure you’re aware, that yoke hanging out that far is probably why the seal is leaking.
I’d run it until I gather up a new yoke and seal and drop the money in a new shaft.
That's higher on the list of sketchy than some of the other things here..
Download the Uber app - always an easy way home (hehe)And one of the main reasons that, since spotting how far out the yoke hangs, I haven't left the airport property with it or exceeded 30 mph with it. That, the brake line, and the radiator waiting to fall out are why I never pressed with tuning the carb in all this time. Those reason are why I suspected there was more, and boy was I right. I feel sufficiently apprised to make a calculated risk decision going forward on when good enough is good enough when it comes time to tune the carb and tweak the ignition.
To heck with those aluminum shafts. A steel 3” shaft is stronger and it will have a lot less tunnel and driveshaft loop clearance issues.
But I completely understand finding something used that can be shortened and balanced with no materials - definitely cheaper.
I was under the impression that a 4L80 and TH400 use the same yoke spline and share the same outer diameter - I could be wrong.
