1984 el Camino 305 won't start
Ok a few questions to get the silly stuff out of the way, first is there a click sound when you turn the key possibly coming from the starter?
2) Can you turn the motor by hand? if so you may just need a starter. If you dont hear anything, then make sure the wire from the battery is good and run a test light off the trigger wire (i would disconnect it from the starter and then attach the test light) have some one turn the key a couple of times and see if it lights up.
Does it have an oil pressure gauge? Any idea of what temp the motor was running when it died? Most 305s I've seen that have been problematic have either been ran to hot for too long, or dumped oil pressure and destroyed bearings...... This would be worst case scenario
I think that's what it may be cause I took it to the shop and they were going through it and they said it's "locked up" internally
