1984 Elcamino
MadMax
Aug 17, 2011
89
6
Hey guys, i still have my monte carlo, but i have an opportunity to get an el camino as well. I'm not sure if it is actually an SS model, but it has all the badging and interior. I'm buying it as a roller for 300 bucks and an old pair of hoosier drag slicks. It's rolling on 4 7" chevrolet ralleys. The car is VERY solid and straight. Do you think this is a good buy? What is there to look for on these el caminos? Any and all help is appreciated!
RITTER
2,385
9
38
Hillsdale, MI
Just you typical rust areas ... lower quarters, frame rails, verticle pillars, bottom door lip, front bed corners :arrow:
As long as its solid, $300 is an awesome deal!!!
88MCsupersport
Aug 23, 2012
51
flushing new york
Thats a great deal i would jump on that in a heartbeat as long as those arears werent rotted out post some pics if you could
MadMax
Aug 17, 2011
89
6
I'll get pics today. The doors have the usual rot along the bottom but other than that the car is solid. It has the GP bars in the front as well. How can i tell if it is a real SS el camino or not?
O. D. Showtime
3,008
3,537
Regina Sask. Canada
I believe up until 80? (not 100% sure) maybe even 81.. that the Z15 (SS code) was on the cowl tag.
I'm sure the 82 and up have to be identified by the build sheet.
$300 sounds like a hell of deal!
88MCsupersport
Aug 23, 2012
51
flushing new york
Check the vin number thats usually how i tell if its a true ss or you can look at the stickers on the doors/ trunk (if they were left on) those codes usually tell you everything about the car such as power doors posi traction ss suspension and everything else ill look at some stuff i printed out a while ago to see if i can get you a website to figure out what the codes mean
88MCsupersport
Aug 23, 2012
51
flushing new york
A sample 1984 El Camino VIN would look like this: 1GCCW809XER100001
1st digit - This is the Country of origin
1 = U.S.A
2 = Canada
3 = Mexico
2nd digit – This is the manufacturers identity
G = General Motors
3rd digit - This is the Make
C = Chevrolet Truck
T = GMC Truck
4th digit - This is the GVWR Brake System
C = Hydraulic brake system - GVW 4001-5000
5th digit - This is the Series
W = El Camino/Caballero
6th and 7th digits - This is the Body Style
80 = 2dr Sedan Pick-up
8th digit - This identifies the engine
9 = V-6, 229cid
A = V-6, 231cid
H = V-8, 305cid
N = V-8, 350cid diesel
9th digit -Check Digit
10th digit - This is the Model Year
E = 1984
11th digit - This is the Assembly Plant code
B = Baltimore, MD
D = Doraville, GA
R = Arlington, TX
Z = Fremont, CA
1 = Oshawa, Canada
12th through 17th digits – Sequential Production Number
100001 – Sequential Production Number
hope that helps i found it on a el camino forum http://www.elcaminocentral.com/showthread.php?t=27738
