On an 85-87 442, I'd just adjust the air pressure in the shocks to get the right height.... 🙂
here's my covid painted GP with the 5409 springs. I would like to get the GP a little lower in the rear but I like the spring rate of the 5409 over the 5413. The 5413 didn't drop the GP as much as the 5409 but I never left the 5413 in the GP long enough for the spring to settle. One other detail is I have an 8.2" rear end so the axle tubes are larger then the axles tubs on a 7.5" so that affects the height. I could put the 5659 springs back in which I have cut to lower the GP but those spring have a 5" diameter which means the airbags I would use to support the rear if the GP is loaded down do not fit.
I just installed a set of 5409 and it dropped the rear about 1.5". I had an antique set of springs in it, but it got raised when I put the Expoloder rear in it so I can't really say how much it changed from the original rear.How much more did the 5409 drop the rear over the 5413?
Is this lower than the 5409? How's the spring ratecompared to the 5409?MOOG 5401
moog-5409 | Pigtail | Pigtail | 13.44 | 7.5 | 5.52 | 0.55 | 143 | 847 | Constant Rate |
moog-5401 | Pigtail | Pigtail | 13.15 | 7.5 | 5.58 | 0.53 | 129 | 727 | Constant Rate |
Bar Diameter - Inches | 0.50 |
End Type 1 | Square |
End Type 2 | Pigtail |
Free Height - Inches | 13.68 |
ID - Inches | 4.30 |
Installation Height - Inches | 10.00 |
Load - lbs | 576.00 |
Spring Rate - lbs per inch | 162.00 |
Spring Type | Constant Rate |
