Well, it's been a while since I've posted any updates on the Cutlass. There hasn't been any progress made on it...I've just enjoyed driving it!
A couple of items I did look at over the past year were...
1. Sluggish at WOT - there was a leak in the secondaries diaphragm for the Holley 4150...easy replacement...FULL POWER NOW!
2. Would not start - the one and only time the Cutlass failed me when I was on my way to a cruise night. I pulled into the local grocery store to get some take-out at the hot food counter, and the starter just clicked. It was just my daughter and son with me, and a local friend gave us a lift home(10 minutes away). The starter had died. I had replaced the solenoid when I put the motor in, but didn't check the internals on the starter itself. Once I got the Cutlass home, I replaced the starter with one I had just rebuilt. So, to replace the starter on my Cutlass... a big PITA!!! Unbolt header, unbolt engine mount, disconnect battery, raise car, unbolt collector, lift/tilt engine towards pass side, remove header, disconnect wiring, unbolt header.... rinse and repeat! Ugh. I'm not even sure that a mini starter would make things easier in my situation. At least it starts effortlessly now.
3. The suspension is way too low in the front! - Ya, it looks cool, but not practical...it bottoms out, and scrapes the collector flanges from time to time. I'll be replacing the front springs very soon (Moog?), and the collector gaskets...with Remflex parts.
Some other plans for this spring and early summer...finish new doors...replace door and T-Top gaskets...service the gauge cluster wiring/contacts... replace the dash/cover up the dash... replace headliner... and find a stronger posi rear end before the 7.5 grenades!
I'll get some pics up when I start the work.
Cheers!
