1987 cutlass supreme
compression on all eight cylinders is fine it doesn't smoke when you crank it up or when its just idling only when you get on it a little engine runs smooth has decent power but your right with the rings because wouldn't it smoke only when you you first start it up and then quit if it was the valve seals thanks for the advice and does anyone have any clue how much it should cost if i pull engine myself then take it to have it rebuilt with new hydr. roller cam, lifters, timing chain, rod, crank, cam bearings, and all other necessary components including machine work on block and heads with standard 3-angle valve job hopefully just honed and reuse stock pistons basically just a stock rebuild and labor.
what I would do ;;;
engine has lo miles so might be full of sludge inside
nothing to loose at that point .....
put an engine cleaner in the oil ( even diesel would do ) let it run idling for 15 -20 minutes .....
change oil & filter
give it a real ride like 50 miles to get the engine really at operating range ....check the temp to be sure it`s at least at 180 deg while you run ....
then check that white smoke you say it does ....is it that intense , or just condensation ?
racing8up said:
with the white smoke could be a bad head gasket that would cause it to run poor just a thought 😀
wtf is everyone problem>????? bad head gasket.bad head gasket,... chill out with that.. dont listen to that moron.. if the car has been sitting up for a while then its burning off carbon deposits man.. run seafoam and BAM!!! your good.. you can say my car lean to the right when i turn my wheel to the left and you will get some idiot saying its a bad head gasket..
Surely, it was resolved a couple years ago when this now dead thread was active. :roll:
seriously search the board about any mechanical problems about any car on here you wil get a goofball saying its a HEADGASKET!!!
Yeah, but why would you a) bring up a thread from 2 freakin years ago to comment on it and b) why do you have to resort to name calling to get your point across? People will tend to not take you serious when you do things like that.
After I pointed out the 2+ year old thread, he continues to rant. And he's a n00b. :blam:
Yes, but he could also be one of those guys who knows everything. :wink:
:rofl:
because i was searching for posts people were posting with the same issues i have with my car!!! and this post was the exact thing i was needing help with and i dont like posting the same threads that people have already posted.. if anything wrong with your car people say it the HEADGASKET!! thats what my point was about.. i dont carE how old the post is.. i just care if it gonna help me or not... thats why we are supposed to be a community.. this isnt a FOXBODY FORUM this is a GBODY FORUM!! SO ACT LIKE IT.. DAMN!!!
