1987 EL Camino V8 305. Aircraft mechanic. Accidently touched battery leads backwards. Now, car starter rotates, all lights work, but no start. No spark at plug laid on exhaust manifold. Checked all fuses and the two metal c.b. in the fuse panel have continuity with ohm meter. Checked the large lug on back of alternator has 13v when battery hooked up. There may be fusable links where battery cable goes to starter lug but haven't jacked up car to check yet. Doesn't seem fusable links would blow with backwards power, but seems it would blow generator diodes but that doesn't seem to answer all of a sudden no spark to a running car. Jumped power from batt to red large lead on coil and still no spark. Yes there is fuel. Smell it when turning over. And used starting fluid to verify. But again checked no start.
Any thoughts? Need my get around car. She moves airplanes in and out of the hangar too.
Car electrical systems are sometimes harder to understand than airplanes.
I know you guys know what's going on.
