The pink wire going over to the base of the distributor is showing 12 volts when ignition is in run position and a little lower voltage when key is in start, with starter turning engine over which I would expect. Car is up on jacks stands and I see where fusible links are attached under main cable connection going up through steel tube to protect them from exhaust manifold. It seems like I would have to remove starter to be able to get to them and test them with needle pushed into ether ends of the wire. I don't have needles at the moment so cut into insulation at the pink wire going into the Distributor base. Same with the main red wire going into coil. I will silicone them up when finished.
The pink wire going over to the base of the distributor is showing 12 volts when ignition is in run position and a little lower voltage when key is in start while the starter is turning the engine over which I would expect.
So I'm now looking to see how to get to the two 10 ga red wires at the ignition switch.
