Back with an update.
I check my thermostat before installing. It's marked 180 degree, and it opened at 183. Not too bad.
I get the Thermo Housing installed along with a few sensors I'll need in place to finish the harness.
I then install the Alt and Compressor, since they both have wiring hookups I'll need in place.
I ended up using the factory headlight connectors since the replacements had a different style terminal.
I lay down all the 12 awg power and grounds along with the 2 relays to begin building the harness.
The 12 awg 280 terminals are a close fit in the housings, but not too bad. I had to stretch the 16 awg rubber weather boots on the 12g wire and then shove them in the back of the connector independent of the terminal.
Cont.......
![MVI_1774.00_05_05_22.Still001.jpg MVI_1774.00_05_05_22.Still001.jpg](https://cdn-0.gbodyforum.com/data/attachments/227/227190-bd337f544500127e377721256e6f75c1.jpg)
![MVI_1774.00_02_07_59.Still008.jpg MVI_1774.00_02_07_59.Still008.jpg](https://cdn-0.gbodyforum.com/data/attachments/227/227191-4c616f5403a76248e5cb44c423961a2e.jpg)
![MVI_1774.00_07_49_24.Still010.jpg MVI_1774.00_07_49_24.Still010.jpg](https://cdn-0.gbodyforum.com/data/attachments/227/227192-12a24a52db881a91a70cbccd5e60a7f3.jpg)
![MVI_1774.00_09_51_19.Still011.jpg MVI_1774.00_09_51_19.Still011.jpg](https://cdn-0.gbodyforum.com/data/attachments/227/227193-ce250c98471f95aedd57d7f22039265e.jpg)
![MVI_1774.00_11_33_32.Still012.jpg MVI_1774.00_11_33_32.Still012.jpg](https://cdn-0.gbodyforum.com/data/attachments/227/227194-3cf4e175f2e7ca84904aee4c8c964346.jpg)
![MVI_1774.00_12_25_51.Still013.jpg MVI_1774.00_12_25_51.Still013.jpg](https://cdn-0.gbodyforum.com/data/attachments/227/227195-35015f903864369d1e2073df01159b11.jpg)
![MVI_1774.00_16_56_45.Still014.jpg MVI_1774.00_16_56_45.Still014.jpg](https://cdn-0.gbodyforum.com/data/attachments/227/227196-40fa6cfe6c22e62b5740f25eac42c490.jpg)
![MVI_1774.00_20_00_25.Still016.jpg MVI_1774.00_20_00_25.Still016.jpg](https://cdn-0.gbodyforum.com/data/attachments/227/227197-286e67bba529f09b5eb2ea190e8671f6.jpg)
![MVI_1774.00_22_08_24.Still017.jpg MVI_1774.00_22_08_24.Still017.jpg](https://cdn-0.gbodyforum.com/data/attachments/227/227198-5729c1c29d4f5b4d3eff63257000a831.jpg)
Cont.......
