BUILD THREAD 1987 Olds 442 Project Build
oldsofb
1,479
4,438
Maryland
www.hutchhiperf.com
Thought I would move the build over here from the 442 page. Here's what's been done so far.
Get the car home
Tear the front end off
Take the engine out
Take the body off the frame
Start to strip the frame
Sand blast the frame
The frame blasted clean
The frame coated
Install Inline Tube rear disc proportioning valve and stainless brake line
Come to grips with rear torque box body rot
Put the F**D 9 inch with rear disc together
Rebuild a Monte SS 12.7:1 Constant Ratio Gear Box
Show off the Dual Quad intake
Test fit the prototype 18 Billet SSIII wheel with silver vinyl inserts and red pin stripe
So that's where I am up till now.
Hutch
Soooo.... some pics won't load. They showed up in the window when i was typing it up. ???
Here's what I did today. I pulled the seats center console and carpet. The floor pans look practically brand new.
Hutch
Your not kidding, that floor pan looks incredible! Looks like you have a great project started. Good luck.
Reactions: Ugly1
My goodness!! You can eat off those floor pans. I'm SOOOOO Jealous. You started with a great car. I've seen your Youtube Vid. I'm glad you're still on it.:popcorn::popcorn::popcorn:
T
Yeah. I had a lot of no money no time wasted on her, but I'm trying to step it up this summer. We'll see. I'm attributing the floors to NO T-Tops and good door seals. With the rust issues in the back, this is a pleasant surprise.
Reactions: Ugly1
No kidding, would have thought you'd be in for much worse. Really nice, great car, looking forward to updates....
Love the look of the rendering, the wheels are nice looking, glad to see the original GM design wheels being reproduced in larger sizes they look timeless.
Reactions: Ugly1
I do love them. At a glance you would think they were stock SSIII's. I need to get the frame back under her to dial in the backspace on the wheel. They are still boxed up with centers and hoops separate. I only have the one prototype that's together. This should help, as I know the backspace on that one, and can see by fitting whether I need to go in or out on the front and rear.
Reactions: olds307 and 403
Finally got a chance to do some more work to the old girl.
Stripped the cluster and trim out of the dash
Pulled the driver side door glass out
Pulled the rear glass trim and the rear valance panel (Holy Crap the flash shows the dirt)
Stripped the tail light wiring and trunk carpet. I found surface rust at both corners in the back of the trunk, but no sign of a leaky rear window??
That's all for now.
Hutch
