442 1987 OLDSMOBILE COIL SPRING ASSISTANCE
JAMES L EUBANK
JAMES L EUBANK
48
CLARKSBURG, WV
I'm looking for any assistance on recommendations for coil spring and shock replacement. I'm trying to bring the vehicle back to its original ride height, but I'm not sure what the factory original spring load rate is on my springs. There seems to be many front and rear spring options depending on load rating and constant or variable types. Can anyone provide me with the original coil spring specifications for the front and rear of a 1987 442? Also, I'm thinking about replacing the shocks with something better than what the factory gave it. Currently, I have the air adjustable rear shocks and the front shocks are the standard OEM. I seen a set of coil spring assisted shocks from Monroe, but I'm not sure if that will make the suspension too stiff. Any recommendations based on ride experience?
rogue_ryder
rogue_ryder
102
Colorado
The recommendation that I took when I ordered up my tubular upper control arms and tall ball joints was "For a car to sit slightly lower with higher spring rates... 5658 for the front and 5401 on the rear." for Moog springs.
88hurstolds
88hurstolds
1,633
83
UNGN
UNGN
2,579
Southlake, TX
When somebody complains about a G-body being "too stiff", the first question I ask is what tire pressure they run, and its usually 36 psi cold.
Even 600 lbin springs won't be jarring with 26-28 psi tire pressure, but the 5658's with bilsteins and tall lower ball joints and the car will ride/drive like the GM suspension engineers originally would have spec'd for a 442 if the bean counters and Lawyers had not intervened..
JAMES L EUBANK
JAMES L EUBANK
48
CLARKSBURG, WV
Thanks for the info, but it turns out that the ride height is spot-on for correct ride height. I purchased a 1987 Oldsmobile service manual which instructs the user on how to perform ride height measurements. However, it does seem to ride a little too loose. This is my first 80s vehicle that I've had in 25 years, so I may not be used to the suspension system of this older vehicle. I may choose to opt for stiffer springs later, but at least I know that the currents springs are good. Thanks again for all of the assistance.
JAMES L EUBANK
JAMES L EUBANK
48
CLARKSBURG, WV
