1988 Monte Carlo LS ProCharger Build (10/12/21 - Back to Painting, Switching directions for power added)
Cool to see there's still progress being made. Impressive efforts for someone that had not done paint work previously.
Tagged in now for more updates.
*Late EDIT"
You guys peeling back the vinyl tops on your rides has me very nervous about my '78. I spoke to my buddy (that has a collision/custom shop) about nixing the vinyl top on mine a while back & he encouraged me to keep it because of its 'period correctness'. My logic was nix the top & do a solid/one color re-paint. That assures everything is sealed. Then, I can do the current vinyl wrap material for the 'look' w/o the known downfall of the old-school application.
It has been pushed off many of times to other projects that are no longer here. I built a big turbo LS swapped 04 Cobra and recently just sold it. I dont like vinyl tops on these cars only because they are known to hold moisture. Luckily this car was not too bad to correct and now it will never see another vinyl top as long as i own it.
Ordered some black seatbelts from seatbeltplanet, we will see what the quality looks like. Also ordered the clutch master cylinder and a new booster so i can install the pedals. Made some more progress on some of the smaller interior pieces.
Got a bunch all cleaned and ready to spray.
All painted!
Will tackle the steering column, rear brake light, kick panels, and lower door panels next. I was trying to figure out what to do for the upper door panels since mine are gray and i didnt want to paint the fabric. Luckily for me my buddy hoarded parts and pulled these down! now to find some straps that are black.
Also i am looking for some black rear panel inserts for the quarter plastics. Anyone make their own? Or did most of you buy them pre-made?
I made my own sail panel inserts out of 1/4 acrylic sheet, but stuck some 6.5 inch speakers in there. 1/8 inch sheet fits loosely in the tabs, but if you upholster them, they should fit snugly.
Little bit of a update, got most of the plastics knocked out today.
Started out by, getting rid of the glue and carpet from the door panels.
Proceeded to clean and get prepped for painting.
Then laid her down while the kid and my wife watched.
Second batch prepped!
And finished!
Also assembled the rear light, looks OEM!
Dash cluster surround with the dash.
Waiting on some dynamat to come in so I can get the carpet trimmed and final set as well as start installing all the plastics into the car. Its slowly coming.
Once the interior is done, ill move on to finally addressing the Fenders and then getting the whole front end blasted and coated in color.
Well slowly been chipping away at small things here and there. Finally got to a good progress point so i thought i would share to my good friends here.
Got the dash swung in and mounted, i took off the dash bezel for now as im working on getting the holley pro dash mounted and wired to a caspers connector so i dont have to hack up the factory wiring to attach to the fuel level, turn signal wires, etc.
Got the rear quarter panels in, i elected to buy new black hardware so it will look nice and sleek. I am remaking the inserts so this will all have to come back out. Also peep the new seatbelts from Seatbeltplanet. I am happy with their quality and price for sure.
Got the drivers and passenger door hardware all installed, new handle gaskets, mirror gaskets, and lock clips. Also had to install a new window regulator on the pass side as it was haywired.
Once i got all of the internals in, i mocked up the door panels to see how it looks. I still need to get new inner and outer felts for the window before I install fully. Also looking for a pass side window switch if anyone has one laying around.
Went to a show up in Indiana and picked up this nice steering wheel, i will eventually make a new insert so it doesnt say SS. I paid $150 for it, but it had all the guts and was in nice shape so I chalked it up to a win.
Got then engine finally set in the car, this is my buddies motor out of his mustang while its in storage. I have a 58x 5.3 that i need to tear down and rebuild in the mean time. I will probably grab some of my extra truck accessories brackets and send them out to be powder coated. I am just getting this car up and running N/A while i get the funds to finish out the forced induction. I used Holley Hooker long tubes and mounts and it fit PERFECT. No hammering, no rubbing, just perfect fit.
Finally made the cut for the transmission, have a stock shifter in it for mock-up will most likely end up with another MGW. I had one on my 6 speed mustang and it was really nice shifting, and could tell it didnt have any slop. I did have to massage the trans tunnel a little bit for the reverse lock out, but it will be not be visible.
I am contemplating using the factory G-Body console, or try and find a 6 speed 5th gen camaro console to throw in it. A local guy around here has one in his car and it looks fantastic.
Also finished tearing apart the factory column so i can get the trim off to paint. Wasnt too hard, but a couple of areas you have to proceed with some caution. I will clean up the internals, replace the bearings and springs and regrease before i complete the final assembly. Need to order some more paint so i can get the trim done and put the column inside the car.
Need to place a pretty large order on some final things to button up the firewall back. Need the headliner and visors, door seals, felt weatherstipping for the windows, also need to get m hands on the cable that runs from the parking brake cable to the spice point under the driver side. SOOOO If anyone has one of those or the window switch i will gladly pay for them lol.
Stay tuned as i progress through the last bit of the interior and start breaking down the dog house to get rid of the LS fender seams.
Just went through your whole build, man what an amazing job.
Star Trek Applause GIF
I appreciate it sir. It’s been about 3 years since I’ve taken possession of the car. Gotten distracted many times on other projects. Hopefully this car will make it to Street Rod Nationals this year. With or without everything completed.
Getting ready to order some more epoxy sealer and 2k high build so I can start working on fenders.
Anyone got a decent hood company for a baby 2” cowl? Prefer steel but not opposed to fiberglass.
Got some time to start working on the car again.
Got the steering column surrounds painted and steering column back together and installed.
Decided that I was going to try to repair the factory headliner since I have been reading mixed opinions on the abs style. Some epoxy, duct tape and some patience we got it looking somewhat normal.
Turned my attention to the rear deck panel and got it wrapped in the same fabric that was used for the door panels. Turned out pretty well.
Then I wrapped the headliner.
Next task was to use some of the “good” quarter inserts to work on making work instead of buying new. Turned out okay, still might stitch them in white.
Got everything installed! Looks great, this was just a fit up. Still need to rewire the courtesy lights in the upper panels and install the sound deadener.
Lastly I turned my attention to trying to connect most of the under dash wiring. Got stumped on these connectors as I didn’t have a clue where they go. Any help identifying? These are under the column area. To help this car is a Monte Carlo and I’m using a regal dash.
That’s all for now folks!
Reactions: UC645 and Rktpwrd
View attachment 232567View attachment 232568
Got everything installed! Looks great, this was just a fit up. Still need to rewire the courtesy lights in the upper panels and install the sound deadener. View attachment 232569
Lastly I turned my attention to trying to connect most of the under dash wiring. Got stumped on these connectors as I didn’t have a clue where they go. Any help identifying? These are under the column area. To help this car is a Monte Carlo and I’m using a regal dash. View attachment 232570View attachment 232571View attachment 232572View attachment 232573View attachment 232574
I might be finding out tonight what the caramel colored wire is, I have it hanging down in my Monte as well
