1988 Monte Carlo SS won't start
OK....just to confirm that connector going into the distributor has both a pink and a yellow wire. Does that sound like the right one?
The yellow wire has a separate connector. That's the signal wire for the tachometer.
I don't see any wires other than the two connectors going to the distributor....look like they attach to the ignition control module. One connector has two wires (yellow and pink) and the other connector has four wires.
What am I missing? Where do I look?
Thanks!
Since i work at a NAPA store im kinda partial to their products. Especially their ignition parts. But AC Delco is a good product to. You really should have the existing module tested. It was a common problem with these cars back in the day. I used to sell the hell out of them, but not so much anymore. U can remove it without pulling the wires off the cap. I think the hold down screws take a 5mm. Good luck. Let us know what u find out.
Thanks!
On the Driver's side of the distributor cap there is a pink wire and a yellow wire. Disconnect both from the distributor cap. They are on separate connectors but are side by side.
A Google search is often times helpful....
[/URL]
Link isn't working for me. Still don't see the wires you are referring to.
My car is a 1988. I think the ignition system changed around 1987. The coil is separate from the distributor. That might explain it?
I have same setup....87 monte with 350 and CCC system. The module and coil would be the easiest and not that expensive
The car has been running nice and most recently had it out last weekend. It is a 1988 Monte SS with 350...all the CCC etc still intact so basically stock other than the 350.
Tried to start it today and it won't fire up. Seems to be getting gas but just cranks.
I'll probably get her towed to the shop after the holiday, but was hoping you guys can give me some things to check. I'm not that savvy as a mechanic so thanks for any help.
Darron
The car has always been very dependable and consistent on how it likes to be handled on start up...so for it not to start up is unusual.
Not a lot of fuel smell. I don't think it is flooded. What's the best way to check for spark?
Should be heavy fuel smell...if not ... maybe not getting fuel
Meh. It cranks. Maybe that fossil of a proto-computer, aka the CCC has packed it in.
