ground for sureAll: I'm beginning to wonder if a faulty bulb is causing a similar problem in my elky. Here's the situation:
Could this also be a ground issue? If yes, where should I begin looking.
- Turn signals work fine.
- However, when headlights are turned on, the right turn signal lamp illuminates and stays ON.
- With headlights on, left turn signal lamp will flash but right turn does not flash on/off.
- Flashers work at all four corners.
