Take a real good look at the shift shaft where the lever is on the transmission.
While having someone shift it with engine off. Check to see if the lever linkage is actually moving the shaft or spinning on the shaft.?
Could be that simple.
If you’ve never ran that transmission yourself you really have no idea what the problem is.
So when shifted from Drive and reverse no movement at all?
