200 R4 shifting issue
200r4
yeah when the balls start falling it'll scare you to death! when i put a kit in mine the pressure regulator would'nt come out of the pump so i hade to pull the trans ,and then the pump :evil: so the lesson is you have to be prepared for anything.
I wouldn't mind putting in a shift kit if that would solve the issue but the GN's come with a 342 rear and they shift into 2nd at around 5000 rpm or higher...this transmission came out of an SS that was running 373 gears and it was rebuilt by a transmission shop about 3000 miles before the guy smacked the car into an immovable object. I'm just wondering if the guy who rebuilt it messed it up. The car wasn't totally demolished and I'm sure the transmission wasn't damaged in the accident. If that's the case the transmission kit won't help.....The one thing this transmission does do is save my tires cause it hits second so fast the car sure ain't going to smoke the tires ... :lol:
I dont wanna steal the thread here. Just a quick question about the adjustment of the TV cable. After you realese it and pull it all the way back, do you keep the cable loose while you fully press the throttle? Or should I say, do I want the cable to slide forward again some? I'm compleatly clueless when it come to these trannys.
they way you adjust it is to push the adjustment all the way back by pressing in the release. The you push the carb to WOT by the lever on the carb and the TV cable will be adjusted as the TV cable is pulled through the lock to it's correct position...so you do want the cable to slide forward...
200r4
when your in wot can you pull any slack on the cable? just a thought
alright, guys. So I was wrong again. Thanks one more time for probably saveing my transmission. lol
