Just got done putting a center console and shifter out of a 2002 monte in my 83 elky! just thought i would have to share this because i see people doing this console with an aftermarket shifter but i got the stock shifter to fit! Got seats out of an 2008 Cobalt going in next.
Taking the gauges out and building my own cluster later on down the road. all the wiring is gutted due to i took the ecm out. a double pump don"t need an ecm A/c is deleted also. got a 350 making 450 HP with a 700r4 behind it.
Please share the shifter furnace process!!! I have 3 of these along with a mint black leather seat combo(front and rear)for my 87 mcss and two more sets of mint grey front seat that I'm using for my 87 elco.I have acres to a couple shifters as I was planning on using b&m aftermarkets,but if the procedure isn't that intense I may go that route?would you be interested in some seats(02 Monte)I could have them shipped to you for a good deal?
Look good! Cobalt seats... kinda curious how there gonna look ... i also have the WHOLE interior from a 03 SS monte carlo. All black have front, back seats with rails. Interior plastics door panels center console. CHEAP
Both those consoles look pretty good. I'd like to see some more photos too, if possible. Was there much fabrication work involved with fitting them into the car?
sorry its been forever. college has kept me super busy! but it didn't take much work at all! the console took some shaving to get to fit right and the shifter all i did was cut some brackets off of it and then put a microswitch on it for park as a safety. the seats took a day to do. took the old seat rails apart and put the part that fixes to the body and mounted 3/16 flat stock onto it for the new seats. spend hours grinding all the rivets out of the new seat rail mounts. used the holes that are already on the new rails and bolted to the old base. little more trimming here and there and its done. it sits kinda high but I'm short so its more set up for me. Gonna make a lower mount for them later down the road when i do my interior.
