I will be crawling under car tomarrow. was way too hot for that messiness today after getting home from work. i already have the 700r4 filter. ordered it up when i got the pan. already ordered new solenoid. it was only 35 shipped . should have it tomarrow. will still be doing the rest of diag testing but since it sounds like the solenoid did not even work properly before since it did not seem to drop enough rpm when on and now not even hearing it click when powered up i would be sure it is one of the issues if not the actual main issue.cheaper to change now then after refilling trans with fluid.
