Hey guys
Last week I was fortunate enough to almost literally "stumble" across an '85 442 in the wreckers. After confirming that the diff was indeed the 8.5" 10 bolt with the desireable 3:73 gears, it "followed" me home last Sunday.
I had posted a request for some info on the axle tube stamping, and forum member Oldsmobile Joe graciously provided me with the info I was looking for. (Thanks again Joe!)
Through THAT discussion, it was made very clear to me from a couple guys here that I should return and grab the 200r4 out of it as it is apparently highly desirable as well.
Well wouldn't you know it, it turns out the transmission "followed" me home as well yesterday after an early morning visit to the junkyard.
Which now brings me to the point of this post:
The 442 was a buckets/console car, but someone beat me to it and snagged the shifter, shifter cable, and the bracket off the side of the pan before I got there.
They left the (broken) console however, so I was at least able to grab the upper insert that has the correct number of "windows" for the light to indicate gear position. So, couple questions here:
Question 1:
Can I use ANY 200r4 pan bracket off of say, a mid to late 80's Delta 88 or similar car?
Question 2:
Isn't really so much a question, but I'm thinking I should be able to just buy a new replacement shifter cable for an '85 442 with console shift from the local parts supply store... Anyone know if I'll be able to or not?
Question 3:
The console shifter in my '80 Cutlass is only the 3 speed for the TH350 that's currently in it. Do I absolutely need the 4 speed shifter, or can my existing 3 speed one be modified to work with the additional gear? Are there only 3 "gates" in my stock shifter, one for each forward gear?
And finally Question 4:
If I'm unable to use my existing 3 speed shifter, anyone got the necessary 4 speed shifter I'd need for sale? I also DEFINITELY need the 4 speed wood grain trim cover to go back on the console. Anyone have one of those for sale as well?
Thanks in advance for any and all help anyone can provide here guys.
Donovan
P.S. - build thread coming soon on Project Olds Cool, the second '80 Cutlass these parts are going into...
Question 1:
Question 2:
Question 3:
Donovan
