200r4 probably asked before question
So the '80 engine has 2-bolt mains? (you first listed it as having 4-bolt mains).
As others stated, this engine is not a '70 LT-1 or even the slightly later 350 that continued with the forged pistons/cranks and better rods (thinking circa 72/74 Z28). So this engine, if just rebuilt stock / mild, would not harm the 200-4R, but you may want to budget beefing it up for a future power increase.
And as other stated your power's going to mostly depend on the heads. You can get the standard Vortecs but will have to limit the lift on the cam to roughly .500" (due to the valve springs). There is another Vortec that can see upwards of .600" lift if I'm correct. Note that Vortec heads will need a Vortec-specific intake as well and the covers are center-bolt. I would stick with a flat-tappet hydraulic cam (you can go roller but there some other things you need to do). A good set of pistons, crank and rods (if reusing the rods at least have them checked and cleaned up). Upgrade the bolts of course. Also, if you go the turbo route, check what the compression ratio needs to be - this is going to dictate the piston and the head chambers used. Also look into the amount of boost the turbo puts out. Lastly, you could always build it as a 383!!
im running the vortech style heads on a 4 bolt main 74 style block, ive heard thats one of the best combos
That'd be nice but I think he just wants a little bit more power that he has...he did say he doesn't race anyone...the nice thing about a stock vortec head is that with the increase of power you'll get better fuel milage too...maybe I should of said "you can get better fuel milage"... :lol:
yes.. im sure the "ability" is there... just not the "will" lol
Oh yeah, agreed. The stock Vortecs are probably perfect. Just thought to mention they can't handle the higher-lift cams unless they are re-worked or if he bought the ones that are already beefed up.
Also agree on the "can get better fuel mileage". Darn right foot :twisted:
I'm looking to drop in a vortec 350 and a T5 WC with a 308 posi in the back. The way my twisted mind works with all the savings I'll be making in fuel milage I can afford to beat on it....lol
pontiacgp said:
if your going to go with new heads you might want to look at vortec heads....and you'll need to change the cam
Along with the intake, valve covers, and some of the accessory brackets as well (Serpentine belt system). Still, a totally worthwhile venture for a budget build.
