i want to put some 24s on my monte but dont wanna lift it is there a way ? and if so be specific on the steps please...!
laman1982 said:i want to put some 24s on my monte but dont wanna lift it is there a way ? and if so be specific on the steps please...!
laman1982 said:good info thanks! do you know were i could find some pics or video of the frame being notched and work that is done to car ? cant find on you tube either bro? just wanna see how much work needs to be done you make it seem easy bro lol and i dont have any 4s to test fit to see were they would rub ...
Bumpin1ohmSS said:Qdub gave you the BEST advice right there bruh. Please do your suspension setup first before wheels. My dogs runnin 4's on their SS' are still on 20+ year old suspension parts and have very little issues. Check my youtube page out for tips on redoing your upper/lower lca's(lower control arms), springs, ball joints, bushings, sway bars ect. I'm running "Coil Spring" airbags from Airlift1000 in my rear springs. I'll be running 4's out back but dropped 3". The bags will help keep your SS' rear level and not sag or dip when turning into driveways and stuff. Also look into rolling your rear fender lip. Thats something else you can youtube. I'd have a shop do it if you dont feel comfortable doin that one yourself. look into beefing up your rear if you are gonna try to do burnout or donuts. Big wheels are murder on stock 7.5 rears when you try to do burns or donuts..
My youtube page. I have suspension rebuild vids for my SS and Elco here as well as other "how to" vids. Scroll down on the right side of the page. You will see em in the titles...
http://www.youtube.com/user/bumpin1ohm?feature=mhum
Here's a homie ridin 4's on all stock suspension...
[youtube]PTDcBc6PWkg[/youtube]
Another showin a clean Aero on 4's. Stock suspension
[youtube]WaYG0PlXd5Y[/youtube]
Hope this helps bruh. OH! Man please dont trip on these dudes on here about runnin any wheel size over 16 or whatever. You run what YOU want on YOUR ride fam.. Hell if you want 30's on there then do it. Just investigate how to do it the correct way...
Elco Warren 8)
80zBabiezCC
andrewmp6 said:So no one has said you have to re gear it to match the bigger wheels?Or bigger brakes to help stop it because of the increase of rotating mass?If you ever see a car go by wot and doing 35mph its not had a gear change is why.
