hey so I got my 260 fixed now and about to put it back in my car and work on the 350 which turned out to be a 79 hurst engine so ill keep it now. I had to bring back the 260 because I work part time make minimum wage and go to school and the gas millage on the 350 was just killing my account but itll be back hopefully better mpg. ok back on the 260 is there any after market heads for it so I can use a 4bbl intake, carb or should I just use a 2bbl to 4bbl adapter. also is it true if one uses electric fans mounted on the radiator instead of the fan on the engine increases mpg, hp because theres less strain on engine. im trying to make the 260 perform alittle better by increasing air flow in and out. do I really need the catalytic converter or can I go away with it since ive seen some cars without them.
