3" OPGI drop springs
deerhunter
Mar 11, 2010
59
6
38
Summerville, SC
I just went and picked up 3" front and rear drop springs from OPGI, I'm wondering what the issues are, if any, with installing these. Any suspension geometry problems? If I understand correctly, the fronts will be OK, but I might have pinion angle problems? Any advice is welcome.
3" seems alot...I suggest you check the clearance of the hump in the lower control and and the frame. When we ran a metric circle track car we could not run the car with less than a 6.5" ground clearance or the frame would be sitting on the lower control arm going through a corner and we were running a 600 lb spring with a big bar....metrics do not have much suspension travel in the front
