Phoenyx said:Leave the engine alone and put some 3.73 gears in the rear.
Third.
Good advice.
and I think you need an external thermostate from what I've heard.monte olrac said:Yes you can put lt1 heads on a gen 1, But the cost is rather pricey you need to have 2 water passages used for the reverse cooling welded shut, plus you would have to get a carb intake used for the lt1, i can't tell you a price but im sure you are looking at well over 1500 to make it work, your best bet would be to mill down some vortecs for compression and go from there
