557752 3B thats what the engine reads so is it a 350 olds then?
idk y i couldnt reply to that forum no kore so i was forced to do a new one but i must of had missed where he posted his answer and so whats good about these motors thenAccording to the info supplied to you by member "oldsmobile joe" in your other post "Anybody know or can guess what engine this is" it is a 77'-80' Olds 350.
last question if i may so should i keep or go swap it for a 454 the transmission seems to be slipping doe n.e opinions thank yallThere are some Olds guys on here that I am sure will chime in on the benefits of a 350 Olds the most obvious is that it directly swaps with the Gbody Olds 307 and adds more power along with the ability to build upon with some aftermarket support.
