307 Olds air/smog pump belt adjustment
The air pump belt met it's match with a pair of tin snips. I'll get the new one back on right away Mr. G-man...
Meanwhile, the power steering belt that needed changed is on.
Reactions: olds307 and 403
Some sort of cutter to remove the belt and later throwing the air pump in the bush is the usual way of removing and not replacing😁.
