How much centrifigul advance does your new distributor have and wnen is it all in by? If you don't know, you would be wise to have your mechanic friend find out for you.
DoubleV said:How much centrifigul advance does your new distributor have and wnen is it all in by? If you don't know, you would be wise to have your mechanic friend find out for you.
DoubleV said:Car looks great, but 28* total timing? That's WAY too low. You should be at about 36* total all in by about 3000.
Put your base timing at 20 ( which what the stock Olds engines were set to ) and that would put your total to were it should be. Are you running ported or manifold vacuum?
81X11 said:That said, the idle is still a little low...feels almost like it's going to stall when stopped in traffic waiting to get out after the show. Never did stall, but felt close. Also, I checked the coolant and it wasn't low. Tonight it never got up above about 210 on the gauge....but it is nighttime.
