DoubleV said:I would advise you to not bother with removing the CCC wiring from behind the dash, at least for now. What you want to remove is the CCC harness from under the hood. It's one big harness that's separate from all the other wiring. This harness goes through a rubber grommet in the firewall under the AC module. You can unplug the ECM from behind the passenger side kick panel and remove harness by removing the grommet from the firewall and pulling it all through the firewall into the car. You'll then need to plug up the hole where the grommet was. I just used a spare old grommet.
Note the grommet is secured by 2 bolts that require some effort to reach and remove. You will have to remove some bolts from the outside passenger side plasic wheel well and pry it out of your way to get to one of the bolts.
The CCC wiring has nothing to do with any of the gauges BUT the speedo does have a speed sensor that sends a signal to the 'speed buffer' which will still be needed for cruise control. Concentrate on removing the CCC harness first, then I can tell you what you need to do to retain your cruise function.
Thanks, and no I do not plan to remove the dash harness, just the underhood wiring speghetti.
Let me ask, is it not possible to cut the wiring under the hood near the a/c evap box and pull what's left from inside the car? Is the grommet attached to the harness itself, or do the wires just run through it? I'd like to retain the grommet and run the wire for the transmission through it. I'm installing a Painless kit for the lockup.
As for removing the underhood harness, I just wanted to make sure my temp, oil, and battery gauges would still work with it removed. Thanks for answering that question!
-Mike
