Anyone have any ideas or maybe I may get lucky and you have done it yourself.
I have a 83 cutlass with 68 sbo 350 in it the water pump and pulleys are all correct for the 68 350 with AC and I believe my brackets are from the 307 unfortunately it has a newer R4 compressor I can’t seem to figure out exactly how to get the pulley system to work and can’t afford a serpentine set up .
At the moment I have the compressor bracket spaced forward pretty much as far as it will go and it has landed the ac belt on the 2nd slot in the pulley. In the slot closest to the block is the alternator and power steering pump though this causes me a small issue because now the power steering pump only has one belt and slips occasionally and I cannot get the compressor to align completely. Also I do believe whatever bracket was used for the power steering may be incorrect because I can’t get it to mount fully and get the pullies to line up which causes it to have a bit of movement.
Any help would be appreciated I’m pretty much beating my head against the wall at this point.
