TeezySupreme said:
DoubleV said:
Get a small cam like I have ( or similar ) which will retain what little cylinder pressure you're making with your anemic CR but will still be better than the crap factory cam. Call a reputable cam manufacturer and get a recomendation from a pro.
If you need Olds specific parts, you should join an OLDS forum where people there have parts like heads for sale all the time. You're not going to have much luck finding parts like this in your local junkyards anymore but these parts are still readily available if you search in the right places ( aka OLDS forums ) for them.
I was on one but the heads i was being offered were cracked and they still wanted a hell of money smh.. that's why i was just going to keep the 8 heads i'm getting them shaved a little and my block is bored .30 over now to spike up the compression a bit but im going to look at a lunati and mondello cam smaller than the one you have thanks for the info by the way..
I always see sbo heads for sale for cheap on the Olds forums but even if you don't see them listed in the for sale section, if you post you need some in the parts wanted section you should easily be able to obtain a set but moving on...
You do not want a cam smaller than mine. I have the smallest cam in the entire Voodoo cam line as is ( and it's too small IMO ). It only has 250/256 advertised duration. The stock cams have about the same ( a tad more I believe ) but much less lift and .05 duration. There's alot more to cams than duration of course so you should really just ask an experienced cam guy for a recomendation but I can assure you you don't need/want anything smaller than what I have.
Just get an ACCURATE measurement on what your actual CR will be and don't guess!
