36MM front sway bar from WS6 T/A
pontiacgp said:
On my street car the stock upper that I boxed elongated the 1/2" hole for the bolt attaching it to the ear to 3/4". If you have the opportunity remove the springs and shocks and make the rear end travel and you'll see the binding that happens on all 4 links when running with bushings. That's why I made the suggestion. I now have the Roto Joint so I can run solid uppers and poly bushings with no bind whatsoever and I'll be replacing my boxed lower with UMI lowers with one Roto-Joint this winter
Can you take the bushing out of the box bar and replace to a roto, or you have to replace the whole bar?
the uppers with the roto joint are adjustable...and that's why I mentioned if you ever wanted to drop in an A body rear you only have to change the part that bolts to the ears
G-Body_Vet said:
I just sold my extra 34mm bar today for $20. I had been trying to sell it for $30 FOREVER. I can't believe nobody jumped on it over the 3 month period it was advertised.....no rust on it either.
You can never find them when you are looking for them. They are a definite upgrade to the F41 bar
Yep, snap oversteer is no fun.
I've done the boxed arms and poly bushings long ago using a kit from Hotchkis. If all you do is drag racing then poly is okay but from my experience, even if a company claims they will make a car handle better it is only in a narrow window.
I switched my rear over to double adjustable uppers with greasable sperical bearings on the frame side and stock rubber bushings in the upper ears of the rear end. Lowers have the same setup except with poly on the rear end side.
The articulation of the rear end is phenominal with this setup.
The down side to using the spherical joints is that they can increase NVH inside the car.
What brand arms did you use for the sphericals? I picked up the Spohn uppers with del-sphere bushings they are saying they are pretty friendly on the street and are better than poly and rubber.
Used the Edelbrock double adjustable arms which are apparently no longer made or were bought out by QA1. But they are essentially very similar to the Sophn bars you have.
The lowers are Currie-trac arms.
So they wouldn't be that great for a street car? I have a upper and lower hotchkis with the braces that i was thinking of putting to use in my GP. Now i won't really be doing any autocross or drag racing yet...
It's too bad I didn't make a video of the movement of the rear end when I had the body off the frame so I could let you see the limitations of a the stock 4 link set up. I really contemplated putting a 3 link system in when you see how much binding there is and the lateral movement of the rear axle that is contrary to the way you want to turn. With the uppers that have a spherical bearing or a roto joint the binding is gone and it's nice and tight. I'm getting the lowers I'm getting a roto joint on one end only because the A boy rear I have doesn't have the same geometry of the bracket on the rear as G body rear.
Guys, the arms feel phenominal. Steering response is greatly improved. Cornering capability is at least 5 times better. The back end keeps up with the front ok. Now it is time to move to the rear brake disc upgrade.
more pics of the install
