BUILD THREAD 36x48x14 Shop Build Update 2/20/2024, Tire Machine is Finished!
ck80
Moderator
Moderator
5,743
9,121
We had spray foam added under and over our old farmhouse we owned outside Atlanta. The one caveat is make sure the area being sprayed is sealed up tight. If the liquid phase being sprayed gets into somewhere you don't want it, it will expand in that space.
If you are going to have a pipe in an area, best practice is to not have the pipes roughed in at spraying, and then use a plastic type pipe in the place you want your permanent pipe. After the foam does its initial set you rotate the pipe left and right to loosen it from the foam to leave a cylindrical tunnel to run your permanent ones through. Works as well if you want to have a channel to run future wiring through, and, don't want to deal with chopping up foam to work on it.
Streetbu
Know it all, that doesn't
3,734
11,581
Central NY
Forgot to add, even if you don't install pex in the concrete, I'm not sure what code is in your area, but here they make you use 2" xps foam UNDER the slab. It makes a HUGE difference too. Otherwise the slab will always be ground temperature. Not ideal when your trying to heat a place during the winter.
Supercharged111
4,932
7,712
Colorado Springs, CO
I saw a build on YouTube where a guy had a layer of sand under the concrete to add mass to what was being heated. No insulation though, seems to me if he'd done insulation under that it would have been even better.
liquidh8
I am working out the numbers to add the pex, I saw about the foam insulation, I am in central PA literally on top of a mountain, so winters do get cold.
I saw something similar.
I'll take some pics tomorrow when/if the crew gets here!
liquidh8
It has begun! A crew of four guys came this morning, unloaded their equipment and tools and got to work. The holes were dug, inspected, and post pills set. The laminated beams are in and the girts started to go up then the sky opened up. They will be back tomorrow to resume, so for now, some pics.
  • Happy
Reactions: 5 users
liquidh8
Progress from yesterday! The crew is here today, finishing up perlins on the trusses, finishing framing the garage doors and windows.
  • Love
Reactions: 6 users
DRIVEN
8,075
14,534
*CENSORED*
You're really gonna like that size. Mine is 36x48 as well, but only 12' height.
  • Happy
Reactions: 5 users
liquidh8
I cannot wait, this part is fast, the rest will take time! I will eventually add on, but those add-ons will be for finished car parking.
liquidh8
How tall is the door gonna be? I only want to make mine as high as I need to, but my camper is just over 12' tall at the A/C.
They are 10x10. I was gonna do 10x12 (high), but I'll never pull anything that big in there. That's my excuse for not working on big sh*t. My buddy has a 30x60 with the same size doors, and works on similar projects so I went that route. The bigger the door, the bigger the air leak you have to plug.
Edit: Same buddy took his AC off and deflated the tires on his camper to get it in the shop for some hardcore wall repair.
