You are right, funny how I missed that. With the block decked .020", which they are decking it that much, a 1.55" piston will be .010" in the hole, so 1.56" piston is also useable. This is an offset ground 330 crank to 3.5" with 6" Scat rod. The Olds 350 bore stock is 4.057". The new Edelbrock heads are 68cc. I want under 10 to 1, we only have 91 non Ethanol Premium here. I am planning on MLS head gaskets, so any thickness is possible. I will talk to Mark and see what his recommendation is, he has built these before. I can still change this up and get the machine shop to do a different final bore. Noise is one thing, no oil control is another.
