383 1980 monte build
thanks deff will
more pics
aluminum radiator and dual electric fan
new transmission crossmember
whats the motor looks like now
now i need a torq converter then some little stuff and she should be ready to go
Motor looks awesome. If the motor runs 1/2 as good as it looks you will be ripping up the blacktop in no time. Good Luck. Keep the pics coming. Lovem more the better. You should have 1 BAAAADDDD AZZZZZZZ RIDE when you are done.
By the way I love the color you painted your motor. It looks very familiar. Great minds think a like.LOL!! 😀 8)
lol forsure
its been awhile since i posted some updates
the 305 and heater box is out of the car now cleaning up the engine compartment
but heres some pic of the body work so far
light blues done were gonna finish the dark blue after the 383s in so we dont mess up the paint in anyway
and heres a updated part list of whats on the motor and what i have for the car
-383 eagle rotating assembly 10.7:1 compression
-Patiot aluminum heads 64cc 2.02 intake 1.6 exhaust
-crane cam 488-510 lift 234-244 duration
-100 long cromoly pushrods
-7/16 1.6 ratio stainless steel roller rocker arms
-aluminum stud girdles
-high volume water pump
-hei 65k distrubitor
-holley 130gph mechanical fuel pump
-holley 770 street avenger carb
-double roller timing chain
-headers
-airgap intake manifold
-1" edlebrock carb spacer
-mint starter
-100 amp altinator
-aluminum water pump and crank pulleys
-aluminum radiator
-dual electric fan
-aluminum trans cooler
-3000rpm stall huges torq converter
-g force trans cross member
-pypes x pipe wiht dumps exhaust kit
and just placed a order to summit for the solid motor mounts, trans mount, floor shifter, and hedman glas packs
That looks like a lot of work. It should look great when your done. Can't wait to see pictures of it when your done with the paint. Keep us up to date on the body work. Good luck.
Looks purdy. Are you going to dyno the motor or at wheels or anything. You plan to just run 93 octane?
thanks
i might dyno it when its all done im right down the street from white racing and they have a dyno , i just have to see how much it will cost
and im planning on running 93 octane and maybe a little turbo blue mixed wiht it to give it that nice smell 😀
i set the motor in it now i just have to start hooking everything up and wait fro the trans to get back from the trans shop
