Re: 3xbrowncutty's Build... 3/2, Apart!!
Thanks guys!
Do you like that converter? I'm just gonna throw mine together and see what it does, if i dont like it, i'll get another converter and throw it in on a weekend or something.
Soo, theres a reason why I havent updated in a while... After the summit run, we came back and tore the bottom end out because i wanted to do the rear main seal. I found a slightly spun rod bearing. And the crank was in pretty sad shape, mains were grooved up as well for some reason. That motor was rebuilt, and the crank was already .010 undersized.
Figured it would be better to find a running 350 with a stock bottom end to throw my top end on. A buddy had one that was thought to be in running condition. Picked it up and tore that down to find rusty bores, minor pitting and an oddball piston. Thankfully he is a good guy, and we worked it out , so i got my money back.
Now back to the 355: I didnt want to take my crank to .020 under, so I ordered a reman crank kit thats at .010 under. Picked that up today, looks good, hasnt been welded. DUe to some peer pressure, I'm getting the flat-tops re-ringed and put on my old rods to up the compression :wink: I'll be around 10.5:1
Everything waiting for assembly.
I also got some paint from work, fixed and spotted in my rear bumper cover, and got the new chrome bumper on. Still have a little wetsanding to do.
The plan right now is to get the motor together and running by this weekend (fingers crossed). Hopefully in the car as well. Might fire it up on the stand to check for oil leaks and break her in a little.
Thanks guys!
86-blk442 said:Heads look great! Your 2k stall might be a little tight for that cam but it should work out. The duration @ .050 on my cam is 230/230 and I have a 2400-2800 stall in my trans.
