secondary lock out seems good too, the little linkage rests against it in HI and once the BF is fully opened, and that counter-wieght is down, its about a 1/4 inch away from it.
Bingo!Pontiac455 said:If I understand correctly then the vechicle runs better with the choke closed halfway while its warm. If thats the case there is a vac leak somewhere. When u are closing the choke its taking air away providing a richer mixture. it all boils down to the engine getting unmetered air from somewhere.
cutlassguy said:i changed the thermostat awhile back and now instead of running at 100, it runs between 40 and 100. anyone know if its just running too cold now and its never at the right temp to operate properly? should i change the thermostat back so it runs at 100 right in the middle?
bill said:just curious...what plugs are you running?
