HELP 4 door/wagon front window channels felts
Nick1979
15
13
26
I'm looking for where to get used or new window channel felts not sure what they're called the ones that go in the window frame. I need it for the front driver door of a wagon or 4 door, mine is completely dry rotted. Anyone have one or does someone make a replacement/universal one. I have two cars that need the front driver side one I'm tired of the air leaks and sagging window when I wind it up. Thanks!
I just did this on my kid’s wagon. I’ll see if I can rediscover what and where I got the channel felts. I bought them online quite some time ago….
Here it is:
I too need these. I remember all the work that went into this thread, thanks guys, you went over and above,. Now to re-read the entire thing and see what I can do.
I picked up strips of window channel that match the GM profile, but I have not sorted out slicing and gluing the corners.
Guys, my good friend Vince ended up purchasing window channels for a B-body car like a Caprice. They apparently are the same profile as the G-body wagon window channels but one of the legs come up a bit short. What he ended doing is using the B-body channels and adding a length from an aftermarket channel, which I'll find the part # for and post it. I would've gone that way had I not found one NOS channel from a GM dealer and purchased another side just for the upright strips.
So, I recommend going to our friends at Rock Auto and purchase them there. https://www.rockauto.com/en/moreinfo.php?pk=1859214&cc=1036594&pt=12412&jsn=1036
Look up '80 Chevy Caprice 4-dr. He was very pleased with how they worked out. The corners are already bonded , so no need to butt them together, except for the added leg.
Part # for additional aftermarket channel AS 1720
Before everyone attacks RockAuto, be aware that the B-body glass is taller and the top strip is not as wide as the G--body opening. I have to find these and snap a picture to support my argument.
Here are the pictures. I'll see whether I can bend the angled joint and simply glue on some more vertical onto the front leg. There is a segment in the left/upper picture where is looks like there is a clip in the channel to keep it in place against gravity when the glass is rolled down.
Reactions: Longroof79
