why not just use a gasket without the steam holes? I can't see how welding up a steam hole is a good idea especially in cast iron and trying to not distort the area of the bore.
We never welded them we drilled and tapped them then Deck The Block.Can;t you just weld up the steam holes in the block? 😎
We drilled and tapped them to plug them then decked the blockwhy not just use a gasket without the steam holes? I can't see how welding up a steam hole is a good idea especially in cast iron and trying to not distort the area of the bore.
When GM designed the 400 cid sbc, to get the displacement they wanted and still have enough sleeve wall thickness, they ended up siamesing the cylinder sleeves. Instead of there being space between each cylinder sleeve, they actually touch each other and the water jacket surfaces at the point where they touch may even have been milled down to make the amount of sleeve to sleeve contact as consistent as possible. The big drawback is that with the sleeves in contact with each other, no coolant can circulate between the individual sleeves as it does with the smaller displacement mills. The coolant that does come into contact with the sleeves ends up superheating because it can't circulate as it should and it this excessive amount of absorbed heat results in it being converted to steam. This in turn creates pockets of air in the coolant which then need somewhere to go in order to cool down enough to return to being a liquid. The steam holes, drilled in both the block and the heads, offer an escape passage that the steam and bubbles can rise up and through to allow them to enter the heads and return back to normal circulation, cooling down and returning back to fluid as they do. It was this steam business that gave the 400s something of a bad reputation for overheating. You cannot mix and match heads. The 400 blocks that have those steam holes drilled in their decks have to have matching heads with hose holes or you will run into all kinds of problems. GM didn't help any as they offered at least five versions of the 400 head under the same part number and some had the holes and others didn't. Right now I am personally chasing a set of those heads with the steam holes and having no luck finding a pair.. As for the the aftermarket, asking a mfgr to drill the holes might be possible but if memory serves they are not perpendicular to the gasket surface, they go in at an angle in order to intersect the coolant passages in the heads. Wrong or no angle and you don't get the passage access needed.= trouble. Hope this helps.What exactly do steam holes do
