what car can i get the transmission and pedals out of to install a 4 spd transmission into my 79 cutlass. It has the 3.8 v6 in now but this weekend I will start to pull that out and put in the 403
Doober said:You will need either a G-Body specific bellhousing and clutch fork (not sure if they make a BOP-compatible G-Body bellhousing), and pedals you can probably find easiest in a Malibu or El Camino, though they're getting harder to come by. Check eBay, also they're sold aftermarket now (though a bit pricey). Try www.ecparts.net, www.opgi.com, and www.dixiemontecarlo.com, they're probably all from the same supplier.
Doober said:...not sure if they make a BOP-compatible G-Body bellhousing...
joe_padavano said:Doober said:You will need either a G-Body specific bellhousing and clutch fork (not sure if they make a BOP-compatible G-Body bellhousing), and pedals you can probably find easiest in a Malibu or El Camino, though they're getting harder to come by. Check eBay, also they're sold aftermarket now (though a bit pricey). Try www.ecparts.net, www.opgi.com, and www.dixiemontecarlo.com, they're probably all from the same supplier.
Or just use a hydraulic throwout bearing and any BOP bellhousing. Solves the header clearance problem with the Z-bar.
You are aware of the Olds pilot bearing problem on non-manual trans cranks, right?
