Intragration said:84clonewars said:As far the swap the 403 is the same size ad the 307 but the 455 is taller. There will be more mods needed for the big block but it cam be done.
No mods beyond the basic Olds V8 mods were necessary to fit the 455 in my car. Even with an Edelbrock Performer it fits under the factory hood insulation using a 3" drop-base air cleaner. Notched valve covers might be convenient.
Some would consider being forced to use a different air cleaner than what they have and notching their vc's to be mods that must be done to make the swap work.
Intragration said:84clonewars said:Yes exactly no major mods needed I was just saying its a Lil more work compared to a sbo.
I'm saying it's ZERO additional work compared to a SBO. If the car is prepped for an Oldsmobile V8, it doesn't matter if it's a 260 or a 455 when you drop it in.
Really? Were you able to re-use your stock sbo fuel line to the carb? What about the AC compressor brackets? Was that a direct fit too? Did you reuse all your sbo belts? Mod carb to work right with the bigger engine?
So what you're really saying is that there are more than 'ZERO' things one must take into account when doing the swap right? Sure, they may not be big things to worry about and some may not even apply, but they are things that people should be made aware of and saying 'ZERO' additional work is a flat out blanket statement that could cause some major headaches for those who weren't prepared to deal with them.
