you will have to cut a hole in your hood or run an aftermarket hood in order for you to run the e-brock intake.. i could barely get mine to close with no aircleaner..
Found that out late last night, the hood closed but I'll have to cut a hole in the aluminum hood under the scoop and cut the rear of the scoop and make it functional with a shortie air cleaner I have.beeterolds said:you will have to cut a hole in your hood or run an aftermarket hood in order for you to run the e-brock intake.. i could barely get mine to close with no aircleaner..
88hurstolds said:...cut a hole in the aluminum hood...
88hurstolds said:I was also thinking of running a remote cone style filter off to the passengers side in front of the coolent tank like the newer cars do.
88hurstolds said:I already have the C's, they were supposed to be large valve but wound up being small valve heads... :?
Well I already drilled holes in it for the H/O hood scoop so it's already fooked...custom442 said:
Yeah, I looked into those but am a little wary of the amount of air flow it provides and if they clear the linkage and choke on Q-jets... I would have to get the KN filter lid as well if I did use one to improve air flow as well since the car is a daily driver.Blake442 said:I have an Edelbrock Performer intake on top of my 455, and with a 3" filter and drop base, it clears the stock hood.
