455 TPI
PC-3215/PC3247/PC2893
OLDSMOBILE 400 425 455
INTAKE & BILLET THROTTLE BODY PACKAGE
INCLUDES BILLET FUEL RAIL KIT
Please note: The bosses for the fuel injectors are only drilled half way in, you will have to finish drilling the hole before installation.
Throttle body:
Uses late model GM Throttle Positioning Sensor
True CNC billet construction, Progressive linkage system for more precise throttle control and better driveability.
Special machined radius on top and bottom of throttle body promotes maximum airflow and minimizes air turbulence. Utilizes a standard square bore 4150 flange
1000 CFM, 1.75” bores.
Manifold:
Our shootout series manifolds for small block fords can be used for serious street performance or race applications, suited toward the 1,500 to 6,500 rpm range. It has a number of unique features such as a rear water crossover passage, nitrous bosses, and four corner water ports. This manifold has a standard 4150, square bore flange.
___________
Any of y'all know if this is a good deal for a person who knows very little about doing this type of conversion?
If I wanted a fuel injected olds, that's the way I would go. Wish I had found this before my build, but I thought it would have been impossible to find a mpfi system for an Olds. Good find.
