yes . i build th400 and 4L80E
If you do that for a living, great. For the rest of us it's a much more time consuming task. And I speak as someone who already has a 4L80 rebuild under his belt.
Do you have a part number. So where do you live and are you up for the job how much.It is very easy lol if it takes you more than 1 hour your doing it wrong. to remove that cup plug in the back, is nothing to do you could even use a screw to take the old one out. And tap the new one in. Attached is a picture of the one you need for 2WD
I believe anyone can do this. Transmissions are not that bad to do. I can understand when you get to higher torque # the difficulty escalates, but at these levels it's almost laughable. you could take your leather belt off and use it as clutches in sections of these transmissions and be successfulIf you do that for a living, great. For the rest of us it's a much more time consuming task. And I speak as someone who already has a 4L80 rebuild under his belt.
https://www.ebay.com/itm/2517437726...pid=5335822911&customid=&toolid=10001&mkevt=1 eBay link I randomly found you could get it cheaper if you look around, I'm sure. and for doing the transmission for you I'm sorry At this time im jammed up Check back with me around August.Do you have a part number. So where do you live and are you up for the job how much.
I believe anyone can do this. Transmissions are not that bad to do. I can understand when you get to higher torque # the difficulty escalates, but at these levels it's almost laughable. you could take your leather belt off and use it as clutches in sections of these transmissions and be successful. Congratulations, supercharged111 in doing your own i encourage everyone to do it.
