Well it begins! I started a thread earlier about the plans for a turbo build which is still in the works but step 1 is to have it running and driving first. I pulled the gmpp 330hp crate and 700r4 from my 86 ss and sold it to fund my build.
Engine: 2000 5.3
799 heads w/ls6 springs
ls6 cam
ls2 timing set
high flow melling oil pump
Trans: 65 th400
32 element sprag
full jakes performance rebuild kit
turbo action full manual reverse VB
2500rpm stall
I built my harness from a factory harness from the instructions on lt1swap.com, a very helpful site for any of you doing this swap. I will be keeping the truck pan, intake, accessories, and ls6 manifolds from a cts-v that are going to work but very tight. I brazed a competition engineering sump to my factory tank, after thorough cleaning at the radiator shop of course. There are many mixed opinions about welding/brazing used tanks but i took every safety precaution. I am using a wally 255lph external pump and all braided lines to the factory rails/regulator. I purchased hptuners suite to do my tuning, along with a innovate lc-1 wideband. To mate the trans and engine i purchased the tq converter spacer and new flexplate.
Pulling her to the shop to pull the old powerplant. A little overkill on the tow rig.
Dont mind the crank snout.....
B&M Pro Ratchet under factory console?? you bet!!
First road block is my motor mounts dont line up. I am using carshop 1" setbacks and some old clamshells i had around. It looks like my mounts are to wide to fit, I can get one bolt in but the other side is off. Anyone else have this problem? What mounts are you guys using?
More progress pics to come as i finish mounting the engine and begin with the wiring and finish up the fuel system.
Engine: 2000 5.3
ls6 cam
ls2 timing set
Trans: 65 th400
32 element sprag
2500rpm stall
