5.3 LM7 running temperature
lolthisisnuts
15
My 5.3 runs around 220 degrees at idle with 185 degree thermostat. Does that seem a bit hot to anyone? I checked my cooling system for leaks and there are none. The t-stat is brand new.
Injectedcutty
G body LS mafia
Nov 24, 2014
6,057
22,811
Louisville, KY
What fan(s) are you running? I have a cammed LM7 with a good sized stall converter and 80E trans....last year on hot summer days mine never went above 210. I'm running Champion radiator, stock thermostat, and dual fans controlled by ecm.
motorheadmike
8,976
27,522
Saskatchewan, Truckistan
PCM tuned for fan on/off temps that match the thermostat?
81cutlass
4,649
13,565
Western MN
Are you reading the temp with the PCM sensor that is in the head, an aftermarket gauge or one that is in the factory dash?
64nailhead
Goat Herder
Dec 1, 2014
5,710
12,219
Upstate NY
Answer everyone's questions in one post and I'm sure you'll find your issue.
