5660 Springs 9/25/2021
mikester
2,921
3,687
Small town NY
FYI.... A 245/45-17 = ~25.7" tall.
Last night I spent some time looking at cars on google and bing images. I found this ad for that wagon in the photo.
Between the info from that wagon and Kamloops cutlass above I think a 235/45 17 or 245/45 might look right on the front with 245/45 or 255/45 on the back. One of my friends recently took his Pontiac to a shop that does custom installs from stereos, tints and wheels. They actually tried a few different combos on his car before they found the right fit. I guess I'll try them. Maybe the wheels are tires might be a little more $$ in the end but at least I wont be stuck with stuff that wont fit. The 5660 springs should be here before the end of the week. As soon as theyre in the car goes to an alignment shop, an exhaust shop and its pretty much finished.
Then the 406 comes out of the 81 to get the oil leak fixed. After I can see how the new springs fit in the wagon I might order the same ones for the coupe. I used Hotchkis lowering springs for the back but never did the front. It sits up a little high. I guess another option would be using the dropped spindles that I just pulled out of the wagon. So tired of working on these cars. I want to be driving them.
scoti
1,978
3,402
Texas
I like my tire sidewall/widths to be as close to each other as possible when running different sizes front & rear.
If you want a 255 on the rear just do the math to get an idea for a consistant match.
255/8 = 31.875.
31.875 x 7 = 223.125 or a 225mm tire. More section width of the tire changes the sidewall appearance. A 235 would be close enough to your target.
mikester
2,921
3,687
Small town NY
I finally got back out to the garage to work on my car yesterday. I feel like a credit card commercial.
New Moog 5660 springs just under $75 shipped
New Moog lower ball joint $18
Used OEM spindles $100
Sandblasting lower control arm $20 ?
Putting it all back together and having it almost the exact same height as before I took it all apart... priceless.
The car sits about a 1/2" higher. LOL
Lots of work for nothing. I still have the lower in epoxy primer. Kinda glad since it got scraped up pretty bad this time (still dont know why) compared to the first time putting it together. Dont know what Im going to try next.
Streetbu
Know it all, that doesn't
3,734
11,581
Central NY
Coilovers and your issue is solved forever. I went thru this for a long time. I can change my ride height in a couple of minutes with just a spanner wrench. Plus it rides better than with cut springs. Running 275/35/18 on all four corners without ANY rubbing whatsoever.
scoti
1,978
3,402
Texas
Please include the dimension from the ground @ the center of the wheel to the fender lip (front & rear) to help him compare where his is vs. yours.
Streetbu
3,734
11,581
Central NY
24.75" must have settled, used to be just over 25"
Kamloops cutlass
413
540
Kamloops bc
Is it possible you did not have dropped spindles before ?
Maybe you just thought you did ?
Your ride height is close to mine that is bone stock
JAMCAR223
1,853
5,507
Houston, TX.
mikester
2,921
3,687
Small town NY
No, theyre definitely 2' dropped. You can see the difference right away compared to the OEM set from the Regal. If I used them with the new springs the nose would be real low. At that point I have no idea what I'd do for tires and wheels.
mikester
2,921
3,687
Small town NY
A lot of us end up trimming half a coil off the spring.
I might put the original setup back in. The dropped spindles along with the taller springs that were in the car when I got it. Especially if its the same.
The front of my 81 coupe if kinda high. I used Hotchkis rear springs to lower the rear but I never changed out the fronts. The bottom of the fender lip is almost 28" from the floor on the 81. A drop will help.
I was going to pull the front tires off the coupe and put them on the wagon today to see how they fit to the inner fender but I wound up power washing my house instead. Tomorrow is another day.
